Old 03-28-2017, 03:10 PM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by crapshooter View Post
thanks. so you can,t use both the bec power and a seperate receiver battery together ?
Yes you can BUT you need to either make a circuit or buy the BattShare unit to isolate each power source for your redundant set-up.
The reason you need to do this as I stated earlier , is that if the battery or the bec in the esc should fail closed then it will short out the other power source and crash the receiver. The circuit that you build or the Battshare will prevent this from happening and give you true , safe, redundant power.
flyinwalenda is offline
