Open or closed gearbox
Hi Mustang,
Just came across your post very interesting read. Have a couple of questions if I may
1. do you use open or closed gearboxes and looking on proto-pic.co.uk website they sell both?
2. (Arduino written in Scratch) Do you know of a way to parallel run functions as I have built a light unit with a quick flash strobe function and a slow beacon. The problem I am having is the code runs linear so the beacon ramps up and down slowly then the strobe flashes but it takes around 15 seconds between strobe flashes while the beacon code runs?
Paul
