I am actually using it on a 20 pole Pletenberg. The plane had a CC 80HV but the ESC failed after two years of use due to a blown capacitor. I will send it along to be repaired. I had good luck in the past with the Jeti so I decided to give it a try once again. Generally speaking, I believe that the Jeti is a better match to an outrunner than a Castle would. The Castle's work, but I think that the Jeti will give you slightly better power.
P.D. The programming is all done now and it seems to work. There is a small dead band between throttle off and throttle on but I will go ahead and fly it and see how it goes. Thank you for the help!
