Originally Posted by
F4 Phantom blue angles
It depends how well your plane is balanced, If your tail heavy, you can still fly,but your nose will be very unstable to any input. Also Maybe,when you mounted your motor, you where not centered on your Datum line on the firewall. Also, your plans might have called for a few degrees of Pan up,down,right or left. Hope this helped a bit
This is true. There is no doubt that the models become more sensitive to the elevator as the balance point is shifted back within the allowed range. But that's easily dealt with by altering the control linkage to reduce the total elevator throw. The model will respond similarly to before if this is done right. But the sensitivity to speed changes from throttle or gusts is reduced by a lot.
