Drill out your fuel clunks, and check every joint in the fuel system to see if it flows well, also check your vent.
I had a tank that everything looked ok, but it was doing the exact same with my 140.. It ended up being the Tank Vent, it had glue slag in it. I ended up replacing the vent.. problem solved.
