Originally Posted by
rupesh rupak
guys, I am buying a micro lathe to build the GR180 turbine. Please help me if this lathe is suitable enough to make this turbine parts.
This is a chinese make "metal worker" brand not sieg. This one is available in my country.
MICRO MULTI-PURPOSE MACHINE
Specifications
Cutting
Swing over bed 140mm
Distance between centers 250 mm
Hole through spindle 10 mm
Spindle taper MT2
Tailstock taper MT1
Spindle speed 100-2000 rpm±10%
Cross slide travel 50 mm
Range of threads Metric version 0.5-1.25 mm (5 thread pitches)
Imperial version 16-24 TPI (5 thread pitches)
Drilling and milling
Max.drilling/milling capacity 10 mm
Travel of drilling/milling spindle 30 mm
Drilling/milling spindle speed 100-1500 rpm+10%
T-slot 8 mm
Motor output power 150 W
Overall dimension (LxWxH) 620x330x570 mm
Net/Gross weight 45/51 kg
Packing size (LxWxH) 690x430x615 mm
I will not be unkind, but do you have knowledge in drilling and milling?
with this sort of machine you will not be happy!
regards Lukacs
