Originally Posted by
AndyKunz
The two receivers need to be in the same class. The AR6335 and AR9350 are in different classes. You need an 8+ channel rx to go with the AR9350, or a 7- to go with the AR6335.
Andy
So Andy, I think I got it. I could put an AR636 in the upper wing, and an AR7350 in the fuselage. Then plug the respective right ailerons into say the Aileron channel of each receiver and the left alerons into say the Alt 1 channel of each receiver. Then make sure both receivers are oriented the same. (Like plugs facing aft and label facing up.). And they will bind and program just fine. Including the AS3X programming. I was thinking of programming the AR7350 AS3X system then plugging into the AR636 and save the program to it.
Sound right to you?
