RCU Forums - View Single Post - Build a Wood Q500 Fuselage
Thread
04-29-2017, 12:46 PM
34
sahartman21
The wing was installed and the process to line-up the tail began.
The pictures shows that an incidence meter was installed on the wing. The fuselage was adjusted until the wing was level (zero incidence).
The tail was test fit and tested with a line level. A piece of plywood is between the "V" and the tail should be adjusted until the bubble is in the middle of the float.
There should be equal distant from the wing tips to the tail tips.
Reply
Like
sahartman21
View Public Profile
Send a private message to sahartman21
Find More Posts by sahartman21
View iTrader Profile
