Day 4:
Decided to put together the left portion of the wing, minus wingtip. This wing went together a lot easier than the right one.
[ATTACH]2212410[/IMG]
[ATTACH]2212411[/IMG]
More than likely due to understanding how it is set up
[ATTACH]2212412[/IMG]
The only thing that I am having issues with now is the leading edge, I am having a hard time getting the birds mouth joint (front of rib) to all sit correctly. I've gotten to the point of gluing in the balsa sheathing in between the ribs.
[ATTACH]2212413[/IMG]
Just need to find my sanding block I have. Also still need to make my Wingtip gauge and Dyhedral gauge.
Pork chop, this will be my first endeavor in the electric rc world, besides the old new bright Rc' s I played with as a child. I will admit that I am not electrally smart.. If you could give you opinion on what gear to get I will greatly appreciate it.
Captcrunch44, I like the idea of setting one wing with no Dyhedral angle and adding the angle to the other wing, it sounds really simple.
Question for the group, along which rib section should I plan to modify for ailerons?
