Get one at Gearbest:
https://goo.gl/Lf8PB2
www.facebook.com/JohnVHRC
Syma has great RC products, every one Ive flown has flown well, and this one flies great as well! The controller is flat, it will fit in a shirt pocket, but it feels great while flying, I never had an issue with the feel at all. The sticks slide instead of how a bigger rc radio works, but it works just fine.
This would be fun in the house on a rainy day, yet still handled the bit of wind I flew it in, in the video, on high rate its pretty fast too. Flips are fast and tight with little altitude loss at all. Its very affordable.
HIT:
- Price
- Extra props
- Flies great
- Flips and rolls are fast
- High speed
- Compact, easy to transport
- Uses a mini usb to charge
- Great range
MISS:
- No complaints
Description:
SYMA X20 mini RC quadcopter is extremely pocket-friendly. Equipped with various functions, including Altitude Hold, Headless Mode, One Key to Take off / Land etc., it is an attractive mini aircraft for flying indoors. More importantly, it comes with a significantly smaller transmitter which can be easily slipped into your pocket.
Main Features:
- Air Press Altitude Hold - auto hover when the throttle is freed
- Headless Mode faciltates directional control in spite of orientation
- Continuous 360-degree rotations towards different directions
- One Key to Take off / Land intended for beginners
- Bright LED lights for flying in the evening
- Mini quadcopter, suitable for indoor flight
Specifications:
Power supply: 3.7V 180mAh lithium-ion battery ( built-in )
Control distance: about 20m
Specification
General
Brand: Syma
Type: Quadcopter
Model: X20
Features: Brushed Version,No camera,Radio Control
Functions: 3D rollover,Forward/backward,One Key Landing,One Key Taking Off,Sideward flight,Turn left/right,Up/down
Built-in Gyro: 6 Axis Gyro
Material: ABS/PS,Electronic Components
Kit Types: RTF
Level: Beginner Level
Connectivity
Remote Control: 2.4GHz Wireless Remote Control
Channel: 4-Channels
Mode: Mode 2 (Left Hand Throttle)
Radio Mode: Mode 2 (Left-hand Throttle)
Compatible with Additional Gimbal: No
Transmitter Power: 4 x AAA battery (not included)
Battery
Battery: 3.7V 180mAh lithium-ion ( built-in )
Flying Time: 4~5mins
Charging Time (h): less than 50 minutes
Dimension and Weight
Product weight: 0.2000 kg
Package weight: 0.2500 kg
Product size (L x W x H): 10.50 x 10.50 x 2.50 cm / 4.13 x 4.13 x 0.98 inches
Package size (L x W x H): 25.00 x 15.00 x 5.00 cm / 9.84 x 5.91 x 1.97 inches
Package Contents
Package Contents: 1 x Quadcopter, 1 x Transmitter, 1 x USB Charging Cable, 1 x Screwdriver, 4 x Spare Propeller
