Mugen C0257 Gaskets
Trying out Mugen's gaskets on my diffs. All the different threads on the www, and a lot of times no one will say what part number to use. You gotta do some reading to locate the item. Mugen Seiki Part #C0257 are a perfect fit. The gasket material of the Mugen brand is almost twice (0.52mm) as thick as Associated's gasket (0.20mm). Opening up the front diff, and found approximately ¾ of diff fluid still in there. With the front diff all cleaned up, I thought there might be a shimming issue. So far so good.
On to the center diff...
