2048 is the DSMX frame rate/resolution . It is not the travel adjustment for the channels.
To set the travel adjustments ,press the scroll wheel to enter model program menu and you will see "Servo Setup" .Highlight that and press the scroll wheel. Now you will see Travel Adjustment and below all of the channels. Adjust each channels throws from 0 to 150%,
To adjust a channels dual rates go back to the model menu and right below Servo Setup will be D/R & Exponential . click on that and when it opens the Aileron channel will be first.
To assign a switch scroll down and highlight Switch then press the scroll button . Now simply move the switch you want and it will assign it. Press the scroll button again to enter it. Now you can scroll back up and adjust the rates for high and low or if you are using a 3 position switch; high ,mid, and low rates.
Highlight Aileron and scroll to change it to elevator and then rudder and set each up the same way.
