I see that the Kracken is a rudder-less wing. This should give you what you need, but don't make the rates too high, or your plane will dive when you bank it into a turn.
You need to put the throttles on different channels, and you will use three separate mixes.
1-Mix the two throttle channels to work together on the throttle stick. Set this mix to be on all the time.
2-Mix the left throttle to the aileron stick. Set it to accelerate with right aileron and decelerate with left aileron.
3-Mix the right throttle to the aileron stick. Set it to accelerate with left aileron and decelerate with right aileron.
Set the mix rate on 2 and 3 to about 20% to start and adjust as needed.
I would be a good idea to put mix 2 and 3 on a switch in case you need to cancel it in flight.
If your airplane had a rudder, these instructions would be different.
