Dromida diff flaw?
I have a Dromida sc4.18bl. While disassembling to clean, inspect, and relube I noticed the outer bearing of the diff shaft was not spinning on the inner race but the whole bearing was spinning. I inspected a little closer and found that there are 4 tabs on the diff. the bearing is going inside these tabs and they are keeping the outer race locked in place. thus causing the whole thing to spin. Because of the width tolerance I couldn't put a spacer in or it wouldn't fit into the case. I therefore cut the tabs off allowing the bearing to spin correctly. both differentials were like this so I did them both. Has anyone else noticed this?
