It's the continuous discharge rate the battery can handle: 30C x 5000mAh (5Ah) = 150A discharge rate. So for the same 5000mAh battery, a 50C battery is rated at 250A discharge rate (see your ESC specifications to see the amp rating it is designed to handle).
192.168.1.1
