Turn on the transmitter first.
There are two ways to cause this.
1) the Rx was bound using the button rather than the menu, so the RF connection can cause a brief jump to failsafe position.
2) the Rx is on before the tx, and the tx connects before it had time to transition the output to the switch position.
So, bind from the menu and power up the transmitter first and you should be fine.
Andy
