Kaos 60 arf wing tube issue
I recently purchased a Tower Kaos 60 ARF. I've found that the wing tube will not go through the fuselage. It seems the plastic tube liner in the fuselage is too tight. The tube fit in the wings is fine. Any solution? the tube liner in the fuse appears to be a thin plastic tube, I don't think sanding it is feasible. Removing it would create quite a bit of slop in the fit through the fuse.
bhady
