At this point, I began adding 1/4" thick pieces of soft balsa cut and beveled to fit the forward section. I continued shaping and adding blocks of 1/4" as needed then started trimming them and sanding/shaping them into the desired contour of the airframe. The turtledeck was sheeted with 1/16" balsa.
