Originally Posted by
Brunswickbmech
that sure looks like the same engine. But I can't fine any reference to it or part numbers
There are engines yet were made in bump as well as pull start versions. Usually the race engines (often designated with "R" in the model didn't come with a pullstart offered. Given the engine you pictured appears to be a 12R with a pullstart, it would appear they did offer it in both configurations. Here's the caveat. Pullstart and bumpstart engines often have different crankshaft timing and sleeve timing - bump engines always make more power than pullstart engines.. Moreover the two WILL have different crankshafts. You will need a pullstart crank, backplate, one-way clutch bearing, starter shaft, and a pullstart to convert your bumpstart engine.
