RCU Forums - View Single Post - How to grind a flat accurately on a LG shaft
Old 08-01-2017, 11:04 AM
raptureboy
raptureboy's Avatar
I assume you are talking about how to locate the flat? I have put some paint on the set screw and then tighten it down to mark the spot where is needs to be ground. I have found the dremel grinds a concave spot rather that flat because of the shape of the wheel, so I prefer to use the edge of a flat file.
