Change the glow plug first. Use a Traxxas 3232x .
If that doesn't solve the problem then check the pressure line from the exhaust pipe to the fuel tank and check the exhaust pipe and exhaust to engine seal for air leaks.
Then check the fuel lines from the tank to the cab for leaks as well as the tank and tank cap.
