I have built several BJ planes and There should be 3 horns supplied and 2 are the same and are for the ailerons, The Rudder is the stand alone. It also tends to be shorter and longer..
So if you check the distance from the tang that is glued in to the control surface, to the hole in the horn. The Rudder is the longer distance.
Hope this helps
