Originally Posted by
Therapy
As a Toolmaker by trade, the word of thumb is full strength is achieved by the threads contact at the same depth as the diameter. So a 1/4 inch nut would be 1/4 in depth. For you it's 5/16. After that little appreciable strength is gained assuming the threads are in good condition which yours obviously are.
You state 1/4 inch thread engagement. By looking at your photos it appears as though your prop nuts are on finger tight. Somebody correct me if I am wrong but I usually end up with some crush on the prop when tightened to what I feel is proper torque. Perhaps that will give you the needed engagement for full strength.
My two cents.
If the engine's prop nuts are being used, would the "spinner" then become purely cosmetic ? If so, the question would be "Is it threaded on well enough to stay in place?"
