Horizontal stab alignment
Well I decided that if one UF is good, 2 must be great! When building this one I've run into an issue with the horizontal stab not aligning perfectly due to where the dowel meets the hole. I've cleaned all the seams, but as you can see there's about a 1mm difference from it sitting flush. Obviously this will affect the incidence, and I'm just curious how big of a deal it is? If it is, how to correct it?
