Originally Posted by
rskiba
Just curious if you can share what the issue was as I am still learning the Jet Central engines. Cheetah just arrived this week at the shop!
What happens is when you install your turbine it needs to learn your fuel system with the pump. As per the manual you must make sure that you see min pump ok then go to full throttle slowly until you get max pump ok. This will set your pump limits for min and max.
As for the to idle error that means that your turbine is not getting enough fuel during the ramping stage and it needs to be raised in the start menu which is the fuel ramp. if you get a ignition error or pre heat then you need to raise the ign pw.
Hope this helps
