Originally Posted by
raptureboy
Cycle it a few times and check the voltage of each cell after each cycle. If any two cells are more than 2/10 of a volt apart I would consider getting rid of it. You should not store lipos for long periods of time fully charged. Always discharge to 3.8 vols per cell for long term storage.
Hi Raptureboy,
- I thought that the Lipo batteries should be at 3.8 volts per cell all the time.
- If not what should the range be that they work in, from the just charged state to run down state and needing a charge?
- Also do you know if there is a way to measure the RPM of an electric ducted fan motor?
I know it’s been a few days but I wanted to fly it again and see the results and get back to the forum here?
Ed
