I cut these in to four brackets as that suited the modified box a little better.
The plate is glued and screwed to the fues firewall with hysol and self tapping screws.
The screws are not removable in that process but it's ok there's no maintenance requirement to remove it.
The next job will be to install the rudder, from memory the kit was a little rough around that area so might need some finesse. Hope I'm up to the job!
