The next few pictures shows the installation of a piece of carbon fiber. You should have everything ready to sheet the wing prior to this point as finishing epoxy is being mixed:
- A 36" x 1/2" x 14 thousandths piece of carbon was laid on the surface.
- I marked the slot location with a marker.
- A razor saw was used to cut a slot for the carbon.
- The carbon was test fit.
- Mix some finishing epoxy and apply on plywood spars and carbon.
- Reinstall the spars and carbon.
