Originally Posted by
chuck l
The reason for wanting to use the switch is to avoid having to retrim the plane for level flight afterwards. I suppose a flight mode could be set up to remember a preset trim. I will explore that.
That would be the easiest way to get a fixed deflection on a switch unless your model has flaps in which case the flap system will give you a predetermined elevator deflection as well.
