Originally Posted by
philjac94
Because they (Jeti) use something better, it's called an Rsat2, the cheapness of a patch antenna but better flexibility being able to connect telemetry and or any of the Power Bus systems Jeti use (CB100, 200, 400)together and throughout the airframe as needed, each one is full range equivalent to any of the full size rx's in their lineup. The USA, while not able to use Rsat2 use the R3 (also full range) instead and get the benefit of channels in remote places...well anywhere they may place the R3.
Thanks for that Phil, but I thought the Jeti Rsat was an complete remote receiver still using mini whip antennae. Cost is 60 pounds in UK.
Need to to talk more about this with Harry C, a converted Jeti user !
The patch antennae I use are just that, patch aerials coupled plugged directly into the dual receiver unit, replacing the "whips".
David G.
