Hi guys,
JPEE,
I certainly hope your able to find some time to put those new parts on your P-51. As you said, if the weather calls for an inside-day that will be a perfect time. Did you get the chance to paint the inside of the fuse yet? I think it's a good idea to clean up the wiring and cover them in the wire armor to protect them, probably lots of areas in a scale fuse for rubbing/chafing.
I did receive the charger and blades but have not found any time to do anything with them yet - may try tomorrow to hook everything up and test it out. Also picked up 2 gens ace lipo's from HF classifieds - every place always seems sold out so took a chance with some used one's. I'll see how they turn out in the long run.
Wanted to show you a few signs that I found while driving around that got bent out of shape by Irma a few weeks ago. Those are some powerful winds to twist the metal that way!
Mark
