The AME has larger ports and higher timing intended for higher rpm. As I understand, there's no difference between the RC or CL versions other than the RC throttle. I've been told that the CL engines ran best on a bladder or if you could manage to get the exhaust to seal well enough to pressurize the fuel tank. I'll try running mine both ways, but will likely end up using a bladder.
