Dominic-
Just as a rule of thumb, an object with a cylindrical cross section traveling through air has about ten times the drag as an airfoil shaped object of the same thickness.
So line drag is indeed very significant in C/L.
Also note that C/L planes require substantially bigger engines than similarly sized R/C planes for the same reason.
