Some More, and remember feel free to ask if you need help with info with the build. If you build with out rushing you could finish it in about 2 to 3 days. This is the first kit that the only thing I glued is the plastic cable supports. The set that I used is same as on the Pilot RC webpage except I put in more flaps (85mm) and 2mm more aileron. All surfaces 25% expo and rudder 40%. Enjoy the flights.
Have a great day
Regards
JB
