Originally Posted by
Hydro Junkie
No guesses? Guess it's clue time:
I'm looking for an aircraft:
1) This aircraft was based on an earlier unaccepted design that had a crew of three
2) In it's first configuration, it was also deemed "unacceptable" by it's country's military
3) After two substantial design changes, it was accepted by the military
4) The redesign increased the plane's payload and crew without hurting performance
5) This aircraft had multiple configurations leading to several different ways it could be and was used. One way was, shall we say, highly innovative
Good Luck
Hydro Junkie; from the outset, this sounded like the Junkers Ju 88. It's hard to judge this early on, but let's try it. Thanks; Ernie P.
The Junkers Ju 88 was a GermanWorld War IILuftwaffe twin-engined multirole combat aircraft. Junkers Flugzeug- und Motorenwerke (JFM) designed the plane in the mid-1930s as a so-called Schnellbomber (fast bomber) that would be too fast for fighters of its era to intercept. It suffered from a number of technical problems during its development and early operational periods but became one of the most versatile combat aircraft of the war. Like a number of other Luftwaffe bombers, it served as a bomber, dive bomber, night fighter, torpedo bomber, reconnaissance aircraft, heavy fighter and at the end of the war, as a flying bomb. Despite protracted development, it became one of the Luftwaffe's most important aircraft. The assembly line ran constantly from 1936 to 1945 and more than 16,000 Ju 88s were built in dozens of variants, more than any other twin-engine German aircraft of the period. Throughout production the basic structure of the aircraft remained unchanged. Design and development
In August 1935, the German Ministry of Aviation submitted its requirements for an unarmed, three-seat, high-speed bomber with a payload of 800–1,000 kg (1,760–2,200 lb). Design of the Ju-88 began with a study EF59 which evolved into two parallel designs, Ju-85 and Ju-88. "The Ju 85 was a twin-engined bomber aircraft prototype, designed by Junkers in 1935. The Reich Air Ministry requested the aircraft, which differed from the Ju 88 due to the use of a twin fin tail unit. The aircraft was never put into service.
Design was initiated by Junkers Chief Designer Ernst Zindel. He was assisted by Wilhelm Heinrich Evers and American engineer Alfred Gassner. Evers and Gassner had worked together at Fokkňer Aircraft Corporation of America where Gassner had been Chief Engineer. Junkers presented their initial design in June 1936, and were given clearance to build two prototypes (Werknummer 4941 and 4942). The first two aircraft were to have a range of 2,000 km (1,240 mi) and were to be powered by two DB 600s. Three further aircraft, Werknummer 4943, 4944 and 4945, were to be powered by Jumo 211 engines. The first two prototypes, Ju 88 V1 and V2, differed from the V3, V4 and V5 in that the latter three models were equipped with three defensive armament positions to the rear of the cockpit, and were able to carry two 1,000 kg (2,200 lb) bombs, one under each inner wing panel.
The aircraft's first flight was made by the prototype Ju 88 V1, which bore the civil registration D-AQEN, on 21 December 1936. When it first flew, it managed about 580 km/h (360 mph) and Hermann Göring, head of the Luftwaffe was ecstatic. It was an aircraft that could finally fulfill the promise of the Schnellbomber, a high-speed bomber. The streamlined fuselage was modeled after its contemporary, the Dornier Do 17, but with fewer defensive guns because the belief still held that it could outrun late 1930s-era fighters. The fifth prototype set a 1,000 km (620 mi) closed-circuit record in March 1939, carrying a 2,000 kg (4,410 lb) payload at a speed of 517 km/h (320 mph).
The first five prototypes had conventionally operating dual-strut leg rearwards-retracting main gear, but starting with the V6 prototype, a main gear design debuted that twisted the new, single-leg main gear strut through 90° during the retraction sequence, much like that of the American Curtiss P-40 Warhawk fighter. This feature allowed the main wheels to end up above the lower end of the strut when fully retracted and was adopted as standard for all future production Ju 88s, and only minimally modified for the later Ju 188 and 388 developments of it. These single-leg landing gear struts also made use of stacks of conical Belleville washers inside them, as their main form of suspension for takeoffs and landings.
By 1938, radical modifications from the first prototype began to produce a "heavy" dive bomber. The wings were strengthened, dive brakes were added, the fuselage was extended and the number of crewmen was increased to four. Due to these advances, the Ju 88 was to enter the war as a medium bomber.
