Originally Posted by
rgburrill
They way those screws are bent suggests you hit a hole in your runway during the takeoff roll. That would account for the mount looking good during run-up but failing on takeoff.
Good point. That may be what happened. It took some force to bend those screws. I'll make the engine mount a bit stronger this time. I'll see if I can fine the resting spot for the airplane. Then check the runway area. Thanks
