RCU Forums - View Single Post - ELECTRIC S.R.W. Self,Rotating,Rotarywing
Old 10-20-2017, 06:07 PM
charlie111
charlie111's Avatar
Default ELECTRIC S.R.W. Self,Rotating,Rotarywing
Watch the 1st. 3 Tests on YouTube! LIFTING on #3 as a WING Motor Mount Broke! Outrunner Motors & C.F. Don't WORK Very Well Together? Last Test Damaged a WING & Linkage! Should make a SUCCESFUL Flight SOON! Spent 1st. Yr. Working on AIRFLOWS & Finally Solved the Problem by Changing DIRECTION of Rotation. Getting Desired FLOWS w/stock Motor Rotation & Props.!!! Have to Pick up Parts/Radios,Typhoon Inrunners & Red Brick SECs on Prototype in N.C.1st.! Hope to Head Down this Month! Join my REVIVAL of Hillers Hornet w/my GREEN Hornet! See it on Twitter Rotate1953 I'm Thinking a SMALL E.V. Could WORK as a Cockpit/Power supply? My LARGER Wings will lift MORE @ Lower RPMs!
