Yes too much flap could be it.
Also check your CG, you might be nose heavy and having to use more elevator throw to hold the nose up . I have mine at around 240mm from leading edge at root and once i did that,ie. moved from 220mm it stopped that slight wing drop on the flare. Even now I could go to 250mm i reckon.
