Originally Posted by
Hydro Junkie
How about a second clue, that first one was pretty vague:
Looking for an aircraft in this quick quiz:
1) This plane was used in combat by a country OTHER than the one that built it
2) This plane never saw combat for it's own country
Good Luck
How about the Heinkel He 112? Germany never used it, but both Spain and Romania did. Thanks; Ernie P.
The Heinkel He 112 is a German fighter aircraft designed by Walter and Siegfried Günter. It was one of four aircraft designed to compete for the Luftwaffe's 1933 fighter contract, in which it eventually came second behind the Messerschmitt Bf 109. Small numbers were used for a short time by the Luftwaffe, and small runs were completed for several other countries, but only around 100 were completed in total.
The Spanish government purchased 12 He 112Bs. This increased to 19. The He 112s were to operate as top cover for Fiat fighters in the opening stages of the Civil War, the Fiat having considerably worse altitude performance. In the event, only a single kill was made with the He 112 as a fighter and it was moved onto ground-attack work. During World War II, when Allied forces landed in North Africa, Spanish forces in Morocco intercepted stray aircraft of both Allied and German forces. None of these incidents resulted in losses. In 1943, one He 112 of Grupo nș27 attacked the tail-end aircraft of 11 Lockheed P-38s forcing it down in Algeria after they re-entered French territory having crossed into Spanish Morocco. By 1944, the aircraft were largely grounded due to a lack of fuel and maintenance.
When Germany prepared to invade the USSR in 1941, Romania joined it in an effort to regain the territories lost the year before. The FARR was made part of Luftflotte 4, and in preparation for the invasion, Grupul 5 v nătoare was sent to Moldavia. At the time, 24 of the He 112s were flyable. Three were left at their home base at Pipera to complete repairs, two others had been lost to accidents, and the fate of the others is unknown. On 15 June, the aircraft were moved again, to Foscani-North in northern Moldavia.
With the opening of the war on 22 June, the He 112s were in the air at 1050 supporting an attack by Potez 63s of Grupul 2 bombardment on the Soviet airfields at Bolgrad and Bulgărica. Although some flak was encountered on the way to and over Bolgrad, the attack was successful and a number of Soviet aircraft were bombed on the ground. By the time they reached Bulgărica, fighters were in the air waiting for them, and as a result the 12 He 112s were met by about 30 I-16s. The results of this combat were mixed; Sublocotenent Teodor Moscu shot down one of a pair of I-16s still taking off. When he was pulling out, he hit another in a head-on pass and it crashed into the Danube. He was set upon by several I-16s and received several hits, his fuel tanks were punctured but did not seal. Losing fuel rapidly, he formed up with his wingman and managed to put down at the Romanian airfield at B rlad. His aircraft was later repaired and returned to duty. Of the bombers, three of the 13 dispatched were shot down.
Over the next few days, the He 112s would be used primarily as ground-attack aircraft, where their heavy armament was considered to be more important than their ability to fight in the air. Typical missions would start before dawn and would have the Heinkels strafe Soviet airbases. Later in the day, they would be sent on search and destroy missions, looking primarily for artillery and trains.Losses were heavy, most not due to combat, but simply because the aircraft were flying an average of three missions a day and were not receiving adequate maintenance. This problem affected all of the FARR, which did not have the field maintenance logistics worked out at the time. On 29 July, a report on the readiness of the air forces listed only 14 He 112s in flyable condition, and another eight repairable. As a result, the aircraft of the 52nd were folded into the 51st to form a single full strength squadron on 13 August. The men of the 52nd were merged with the 42nd who flew IAR.80s, and were soon sent home to receive IAR.80s of their own.
A report from August on the He 112 rated it very poorly, once again noting its lack of power and poor speed.For a time, the 51st continued in a front-line role, although it saw little combat. When Odessa fell on 16 October, the Romanian war effort ostensibly ended, and the aircraft were considered to be no longer needed at the front. 15 were kept at Odessa and the rest were released to Romania for training duty (although they seem to have seen no use). On 1 November, the 51st moved to Tatarka and then returned to Odessa on the 25th, performing coastal patrol duties all the while. On 1 July 1942, the 51st returned to Pipera and stood down after a year in action.
On 19 July one of the He 112s took to the air to intercept Soviet bombers in what was the first night mission by a Romanian aircraft. As the Soviets were clearly gearing up for a night offensive on Bucharest, the 51st was then re-equipped with Bf 110night fighters and became the only Romanian night fighter squadron.By 1943, the IAR.80 was no longer competitive, and the FARR started an overdue move to a newer fighter. The fighter in this case was the barely competitive Bf 109G. The He 112s found themselves actively being used in the training role at last.
The inline engine and general layout of the German designs was considered similar enough to make it useful in this role, and as a result the He 112s came under the control of the Corpul 3 Aerian (3rd Air Corps). Several more of the He 112s were destroyed in accidents during this time. It soldiered on in this role into late 1944, even after Romania had changed sides and joined the Allies.
