Hi
I'm wiring a trex nitro with a 3gx system. I have my power and ground on two separate contacts, and rather than rewiring them I was wondering if the below setup would work?
Also, I guess the power should go directly to the battery pack right? I'm using the following battery:
Previously, the system was setup with a VBAR and calibrated perfectly. With this new 3gx, do I need to redo the mechanical calibration, or can I setup it all from the controller? The 3gx is already paired with my DX8 from previously as well.
Finally, any knowledge about the 3gx version 5? Should I upgrade from my version 3?
Kind Regards,
Peter
