TIG
Brushless motors of 750 Watts power can readily go up to really high speeds but you don't say what the turbine 'ignition' speed is. Knowing the required speed will allow an appropriate motor/battery voltage combination to be selected..
I assume you will have some mechanism to uncouple the motor once the turbine self sustains.
