Aluminium Tape Covering
Hi all,
I have just taken on a friends unfinished war bird project (An SC 120 4 stroke powered P51 Mustang built from plan).
In the main the body is almost finished leaving just the main wing and a few odds and ends to finalise.
The guy I got it from clearly had grand plans for build and had started to cover the fuselage in alloy tape. This is not a technique I have ever seen before and have only been able to find one video of it on you tube in which a guy covers a simple foam delta wing.
I would love to finish the model in this way as it looks fantastic. The friend had even started going over each panel of tape applying rivet detail with a narrow hexagonal copper tube he was pressing into the covering.
If anyone has ever covered a model in this way and has any tips and tricks to share I would love to hear from you. I'm interested in understanding how the structure under the tape should be prepared (Varnished / Just sanded ect)? Should the tape panels be overlapped and is adding rivet detail by pressing into the tape best way?
Any help would be greatly appreciated, many thanks
PS: I've only snapped one pic of the model so far (as i was collecting it and squeezing it into my car), ill add more as soon as possible.
