Originally Posted by
Blueyonder
Sounds good, thanks... Good luck with the assembly.
It will be a while before I get it together as I have a Craft Air Mystique on the bench at the moment. I did weigh all the parts of the new Tiger 3 and it is about 14 oz heavier than the original. I am tempted to try to fly it on a .46 as the smaller one is over-powered with that size engine. I am sure a .91 would give it incredible vertical performance, but I normally like more scale power to weight ratios. I competed in Scale Master for several years with a 100 inch span 13 lb Twin Otter that flew on two .28 FSRs running 3 blade props. Did fine off a grass runway.
Looking forward to having two Tigers to fly in the spring!
