Originally Posted by
Novice_builder
Hi Andrew
You've done a fine job on your first model!
As others have advised get an experienced modeller to fly the model for you at first to check that everything is ok. You could then fly the model on a "Buddy box," a system whereby the instructor and pupil's transmitters are linked by a cable so that the instructor can regain control if the novice gets into difficulties. This is less wasteful on models than the "Grab-The-Transmitter" method with which I was taught! You do not necessarily have to use a genuine Spektrum cable, any cable with an ordinary (mono) mini jackplug on each end will do and these cables are readily available in electronic components shops. With the Spektrum Dx6i you can also link your transmitter wirelessly to most of the rest of the Spektrum transmitter range.
I strongly recommend that you join a club. The club's fees will include third party insurance which could be useful if you were to hit anything with your model, besides you will make lots of new friends with a similar interest.
I noticed the small Union Flag on the fuselage. Does this mean that you are British? If so the following will help you find your nearest club. Best of luck!
https://bmfa.org/Clubs/Find-a-Club
