I found a bottle of ATF in the garage, appears to be a just a little thicker or heavier than BVM thin lube. I plan to try using it since that is what Skymaster uses.
I am still waiting for guidance on how much oil to put in ??
I also forgot to ask.......there is a socket head screw a little bit below the brass bleeder valve. What does it do ?
