Originally Posted by
JohnBuckner
Two other work arounds to this problem. First the larger the tank the longer the internal flex line and therefore the more flexable it becomes. So moveing perhaps from an eight ounce to a ten ounce just may take care of the problem.
If that is not desirable or possible then give consideration to how you have assembled the bung plug. How much of the solid through tube do you have protruding past the backside of the bung plug. An excessive protrusion here will rob flexability of the internal pickup line. I like to keep these protrusions quite short on the smaller tanks for this reason.
John
From what I can decipher from the OP's posts, I think that you have the answer.
