Here is all the instructions say for the Mini-Plane:
A jig saw is best for cutting out the printed balsa parts. Cut just outside the lines, leaving all the line on the part. When fitting into place in the structure, use a sanding block to bring the edges to an exact fit. If an X-Acto knife is used don't cut too close to the lines but leave enough margin to true up and finish the edge with a sanding block.
After reading through the instructions, I am curious as to why Corsair013 picked a biplane as a first kit to build. While it's not a hard plane to build, it isn't exactly what most would pick as it does have some areas that are a bit "complex"
