RCU Forums - View Single Post - Top RC Models MkIV full Composite Spitfire-a game changer
Old 12-20-2017, 04:22 PM
  #588
zrooster
Originally Posted by Dsa44
Thanks, I think I will use some sort of shim around the hole, maybe try to cut down the O-ring.
I haven't found it, but I do wish there was some communication between the wing exit holes for the servo leads to the gear servo and the aileron-flap servos. If there is, I haven't found it. It seems the spar-tube blocks the path. It would be nice to use one of my custom single-connect MPX connectors for each wing. I guess I could do a single multiport connector to the aileron-flap, and then do the gear as a second connection. Unless someone has done it?
Not much help to you, but mine was smaller, and I used it as a cushion/guide for my ele pushrod. As for servo leads, I have my LG and aileron/flap leads coming in-in separate locations (ail/flap in one place, gear in another). Was looking at doing the multi port thing, too... I'll post if I come up with anything better than what you've got...
