I moved too. It is pretty windy here for 1/2A. A .15 is good. Some pics here, the blue foam is 1/2" and ok for 1/2A. That one is an AP .09 and pretty big at 36" and 24" long. Still not finished since 2014.Likely will put on a pipe if it flies ok. You could make a quick one maybe the same dimensions and outlines as what you have. The white one is a 1/2A control line speed, monoline and it never really got too high off the ground. Wore the prop down.very small. It was a gift.probably over 30 years ago.(40?)
