Originally Posted by
partshunt
Compression may be the cause as it wont even fire intermittently, just nothing, nothing and more nothing. Any ideas?...Thanks.. Joe
First off....I know NOTHING about a Morton.
To check if its compression....inject enough oil into each cylinder to drip down around the pistonskirt/ring to allow the piston to seal. Treat each cylinder then give it a feel for increased compression and a try at starting. Also since its gas it will wash the oil off quickly.
If it works....consider running oil/more oil in the gas.
